MSE NTP issue
wireless wlc
  MSE3355 running 7.0.201.204 . NTP is configured in intial setup and synced with NTP server. but when i see the time, its offset by 6 hours. I have set the timezone correctly as per the location we are in and it still shows wrong time. Is there anyway i can configure a time offset (+6) or something in MSE CLI (linux) so that it shows correct time ?
MSE is added in NCS.
regards
Joe
ramkris2
Hi Joe,
The time should be coming from the /etc/localtime so comment the line from /etc/sysconfig/clock to look like
#ZONE=UTC
set the timezone using the command:
cp /usr/share/zoneinfo//  /etc/localtime
Make sure the NTP server shows the right time. Sync the ntp server & restart the service using the following commands:
ntpdate -u
service ntpd restart
Ram
