Showing results forĀ
Search instead forĀ
Did you mean:Ā
MSE unable to track clients and rogues but not tags
I have just set up  a CAS infrastructure:
  • MSE: 7.4.100.0
  • Prime Infrastructure: 1.3.0.20
  • WLC: 7.4.100
Every things seems to be OK.
  • MSE Partner Engine is running and Tags are positioned in maps
  • I have both permanent licenses and demo license so that should be ok
Wireless clients are counted not counted while tags are counted. However, I see that there are active clients in the page below:
But they do not show up in the map screen.
Below is the output from msed status:
Context Aware Service
Total Active Elements(Wireless Clients, Tags, Rogue APs, Rogue Clients, Interferers, Wir
ed Clients): 27
Active Wireless Clients: 0
Active Tags: 27
Active Rogue APs: 0
Active Rogue Clients: 0
Active Interferers: 0
Active Wired Clients: 0
Active Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired Clients)
Limit: 1000
Active Tag Limit: 100
Active Sessions: 1
Wireless Clients Not Tracked due to the limiting: 0
Tags Not Tracked due to the limiting: 0
Rogue APs Not Tracked due to the limiting: 0
Rogue Clients Not Tracked due to the limiting: 0
Interferers Not Tracked due to the limiting: 0
Wired Clients Not Tracked due to the limiting: 0
Total Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired Clients) N
Context Aware Sub Services
Subservice Name: Aeroscout Tag Engine
Admin Status: Enabled
Operation Status: Up
Subservice Name: Cisco Tag Engine
Admin Status: Disabled
Operation Status: Down
Version: 04.04.02.04 - CIL3
Description: AeroScout® Location Engine for RSSI and TDOA asset tracking
Active: true
Engine flap Count: 0
Failed Connection attempts: 1
Any idea what can be wrong?
thanks in advance...
Knut Eilif Husa
An update on this case:
After a lot of troubleshooting with Cisco support things have eventually started to be sorted out.
The problem seems to be an incompatibility (read a bug) in the MSE that does not handle RSSI measurments coming from single band Access Points (2.4 GHz). When we received a dual band Access Point from Cisco, things started to work as expected. This behaviour is consistent with the logs displayed further up in this post.
A bug is now filed in the Cisco system, and I am awaiting the answer on how to proceed.
19 Replies 19
Scott Fella
On PI, under the mobility service engine, make sure you enable the type of tracking you wish to do. It should be under the Context Aware section.
-Scott
On PI, under mobility service engine ->context aware services, the following screen is shown which indicates that clients are tracked:
Under mobility service engine-> General, the following screen is shown:
It says that client should be tracked even if the Cisco CAS engine shows status down.
I have checked in WLC that the clients are seen:
show client detail:
Nearby AP Statistics:
      APacf2.c506.a7c9(slot 0)
        antenna0: 47 secs ago.................... -86 dBm
        antenna1: 47 secs ago.................... -82 dBm
      APacf2.c506.a782(slot 0)
        antenna0: 47 secs ago.................... -71 dBm
        antenna1: 47 secs ago.................... -77 dBm
      APacf2.c506.a7ce(slot 0)
        antenna0: 47 secs ago.................... -59 dBm
        antenna1: 47 secs ago.................... -55 dBm
      AP0006.f616.e708(slot 0)
        antenna0: 47 secs ago.................... -57 dBm
        antenna1: 47 secs ago.................... -52 dBm
      AP0006.f66b.d3d6(slot 0)
        antenna0: 47 secs ago.................... -63 dBm
        antenna1: 47 secs ago.................... -65 dBm
But they don't show up in the map...
Scott Fella
Did you add the MSE to the map? Make sure you apply the MSE to the floor plan and sync the the two.
-Scott
Yes, they are synced as far as I know:
Try to sync it again. I don't know what else you can do except of removing and adding the MSE again. If the MSE is a virtual machine you need toile sure the hardware requirements are meet or else it will not show you devices also. The CPU and Memory has to mat h the level of the license you have installed.
-Scott
Yes, the MSE is a Virtual Machine. I will check the HW requirements.
Is there any log file on the MSE which I could look into that could give me some idea?
Please refer to this link. If your requirements are not meet then yes you will not see the clients
http://www.cisco.com/en/US/products/ps9742/products_tech_note09186a0080bb497f.shtml#resource-reqs
-Scott
I have now been trying to search through log files to see if I can find any reasons why clients are not tracked.
Under I paste the following excerpt from the logserver.log file
MeasurementNotification-message-225.Groups.0.Entries.5.ApRssiMeasurements.Entries.1.ApMacAddress = 84:78:ac:f0:81:20
MeasurementNotification-message-225.Groups.0.Entries.5.ApRssiMeasurements.Entries.1.AntennaId = 1
MeasurementNotification-message-225.Groups.0.Entries.5.CcxTagPayloadList = null
MeasurementNotification-message-225.Groups.0.Entries.5.TransmitPower@729103289
MeasurementNotification-message-225.Groups.0.Entries.5.TransmitPower.Value = -128
MeasurementNotification-message-225.Groups.0.Entries.5.BatteryStatus = null
MeasurementNotification-message-225.Groups.0.Entries.5.Chokepoint = null
MeasurementNotification-message-225.Groups.0.Entries.5.ChokepointOptions = null
MeasurementNotification-message-225.Groups.0.Entries.5.SequenceRange = null
MeasurementNotification-message-225.Groups.0.Entries.5.RssiSource = null
MeasurementNotification-message-225.Groups.0.Entries.5.DirectedStatsList = null
MeasurementNotification-message-225.Groups.0.DeviceCategory =
MeasurementNotification-message-225.Groups.0.EntryCount@497288441
MeasurementNotification-message-225.Groups.0.EntryCount.Count = 6
MeasurementNotification-message-225.ServiceDescriptor@2067957410
MeasurementNotification-message-225.ServiceDescriptor.ServiceId = RSSI
MeasurementNotification-message-225.ServiceDescriptor.ServiceMask = 1
MeasurementNotification-message-225.EntryCount = null
MeasurementNotification-message-225.Context@1284846822
MeasurementNotification-message-225.Context.SequenceNumber = 225
MeasurementNotification-message-225.Context.MessageId = MEASUREMENT_NOTIFICATION
MeasurementNotification-message-225.MessageType = NOTIFICATION
MeasurementNotification-message-225.Rawbytes = null
MeasurementNotification-message-225.NanoTimestamp = 486808371199663
4/10/13 06:56:36.54 TRACE[location] [35] AesLocationModule.handleModuleMsg handle NMSP Msg
4/10/13 06:56:36.54 INFO[location] [46] Failed to find heatmap for AP interface 84:78:ac:f0:81:20-5.0-0
4/10/13 06:56:36.54 INFO[location] [46] Failed to find heatmap for AP interface 84:78:ac:f0:84:b0-5.0-0
From this I see that all client/tag measurement information is received by the locationserver, but that AP heatmaps cannot be retrieved.
From the Matlab-process-heatmap-engine.log I see the following:
4/09/13 10:47:31 INFO[location] [11] MatlabHeatmapBuilder#createAPInterfaceHeatmap CREATE heat map (heatmapkey,binsize,rssiCutoff): 84:78:ac:f0:84:b0-2.4-1 8 -112
4/09/13 10:47:31 INFO[location] [11] MatlabHeatmapBuilder#createAPInterfaceHeatmap Calling Matlab method site_survey_ap_info_compute_heatmap
So the heatmap key created is: 84:78:ac:f0:84:b0-2.4-1 but the one asked for is: 84:78:ac:f0:84:b0-5.0-0
Can this be a reason why the clients are not tracked? And what does the trailing part of the mac key, -2.4.1 vs. -5.0-0 indicate?
BTW I saw that the same seemed to be the case in this thread:https://supportforums.cisco.com/message/3905306#3905306
Today i just reinstall mse application on server and it didnt help(
I have been trying to figure out what is going wrong here. What seems to be the case is that the matlab heatmap engine generates RSSI heatmaps for 2.4 GHz antennas which is correct according to our installation. However, when RSSI measurements are posted to the MSE it looks for RSSI Heatmaps for the 5.0 GHz band, which does not exist (We do not have dual band antennas). I have posted a support task on this through our Cisco supplier and will follow up on this.
Please let me know if you solved this problem
Thx
and me pls
LF007
Make sure the maps in NCS are assigned to sync with the MSE.
