MSE, upgrade: kernel panic (.iso)
Jaaazman777
Level 3
Level 3
Hello!
I faced the problem during the upgrade from MSE 7.2.110 to 7.4.100.
All steps were done according to
http://www.cisco.com/en/US/docs/wireless/mse/3350/release/notes/mse7_4_100_0.html#wp1244719
on step 8 I uninstalled the existing software with the command:
  cd /opt/mse/uninstall
  ./unistall
After that I tried to iniate the install process of MSE 7.4 bin file.
After several time reboot the system went to kernel panic. It was seen from monitor, plugged to MSE, not in the console from serial cable.
Is it possible to recover the MSE or find any .iso file?
Scott Fella
You would need to open a TAC case and they can provide you with a recovery image. I would thing that you will need to reinstall the MSE software using the image TAC provides.
I never perform the uninstall. Just the install and then I delete the old files.
-Scott
Scott Fella
-Scott
Scott, thank you for the answer!
I will contact the cisco TAC
About uninstall:
After several attempts of upgrading the MSE I also realized, that there is no need to uninstall the existing software.
Nevertheless, why Cisco recommends to uninstall it?
Step 8 Uninstall the existing MSE software. Choose deletion of database when prompted.
Scott Fella
Yes they might, but look what happened! Now next time you upgrade, you will remember to skip that section. I tested that in a vMSE in my lab and also failed when booting up. So if you have a vMSE, perform a snapshot and try to uninstall it again since you can revert back. An appliance on the other hand, well... Now you have to spend a couple hours to get it working again.
-Scott
