MSE
amrelquasaby
Community Member
I have installed a MSE virtual machine and make the basic configuration, and I want to integrate it with a Prime Infrastructure.
After adding the infos of MSE on PI, a pop-up message appear that the server is unreachable or the hhtps is not supported.
I have entered the ip address of the MSE, username and password.
I have tested the connection for both MSE and PI.
Appreciate your support
0 Replies 0
