Mulitple SSIDs and ACLs on Autonomous APs
This is an unusual situation:
I have the need to run a few autonomous APs (1262) for some sites on satellite links.
At a bare minimum I need to run two WLANs.
One is wide open, and the other with an ACL that heavily restricts access.
Is there any way to tie two WLANs to a single VLAN, while applying an ACL to just one WLAN?
Any ideas?
You would need to setup multiple vlans. Here is a doc regarding autonomous and ACL's.
https://supportforums.cisco.com/docs/DOC-13768
-Scott
Scott Fella
On autonomous, you cans have multiple ssid pointing to one vlan.  You can on a WLC.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Kind of figured that.
I guess I will have tpo deploy another VLAN/Subnet...
I take it that I can run an extended ACL on an autonomous AP and apply it to the dot11 radio subinterface?
-Scott
