Multi Country Controller Problem
mahdi.rashgi
Community Member
Dear Colleagues
I have a 5508 WLC  and I have Configured controller for multi country regularity domain (-A , -E) because of my APs regularity domain. when my APs joint to the WLC for the first time, their admin status were disabled by default.
My question : is there any solution to change this default WLC behavior?
Best Regards
I am one of the few believers that configuring conflicting multi-domain country codes DO NOT WORK.
The best bet is to separate controllers based on different domain code.  With the advent of the universal regulatory domain code, this will be a thing of the past.
Leo Laohoo
Talk to your Cisco SE/AM or your supplier.  Cisco has started rolling out APs with universal regulatory domain code of "-UX".   Due to sales reasons, not all APs will support "-UX".
The app for the iPhone can be found HERE.
For Android, it’s found HERE.
Cisco Aironet Universal AP Priming and Cisco AirProvision User Guide
Dear Leo Laohoo
Thanks for your answer, I will consider your solution for my future purchases, but there are some reasons that I need the admin status of my multi domain APs become active for the first time they join the WLC (this is the default behavior for a single country regulatory domain), is there any configuration or command on WLC?
Abhishek Abhishek
I don't think there is any solution to change the default behavior of the status being in disabled state.
