Multi-VLAN support over Mesh
MK231
Level 6
Level 6
for using the "Multi-VLAN support over Mesh" - feature, does this still need to be activated by support?
Regarding documentation, there is still a need, but is this up-to-date?
Thank you,
Marcel
Brash
Meraki Community All-Star
Yes, I believe it still requires support to enable.
Ryan_Miles
Meraki Employee All-Star
Yes, only Support can enable it as it's a static command specifically on the repeater AP. I hope it someday comes to the UI.
