Multi WLAN authentication question
twikel
Community Member
Infrastructure:
WLC2500, PEAP MS Chapv2 authentication thru a single IAS
PCI WLAN with AD Security group
Internal WLAN with AD security group
Scenerio:
I need to set up seperate authentication for each WLAN with it's appropiate AD security group.  In other words, the PCI users can only authenticate (through the PCI WLAN) to the PCI AD security group.
Potentual issues:
Can't have the Internal user authenticating to the PCI network.
I've racked my brain on ways this can be done and I'm not wanting to create a 3 armed monster.  Does anyone have any "best practices" ideas on how to easily accomplish this task?
Stephen Rodriguez
The only way I can think of would be NAR. Ate a policy that they ant connect to a specific DNIS. But I'd have to look to see if IAS supports it or not
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Scott Fella
You need to have 3 policies create in IAS. Each will define the ssid and the AD group the user belongs to. So on the wlc, do you have 3 ssids and each has it own vlan?
-Scott
What you need to use is the called-station-id radius attribute that is passed to IAS. You can specify a regex for that ex. *SSIDA
-Scott
