Multicast HELP!!!
mjohnson1914
Level 3
Level 3
Helllo Folks,
I am trying to configure mulitcast on five (5) 5508 WLCs but I need some clarification on how this is done ... I read through the config guide and I have a basic understanding on how to configure it but I just don't know if all WLCs should have the same Multicast IP or different IPs.  If they should have different IPs should they be in the same range or does that matter.  All of the controllers are a part of a mobility group and the client could possibly roam between the controllers so I am just trying to find the best way to configure the controllers to enable multicast ... I got the application working on the wired side but it's currently not working on the wlan.
Any help would be greatly appreciated!
Thanks in advance!!
Stephen Rodriguez
Each controller should use it's own multicast group.
https://supportforums.cisco.com/docs/DOC-14713
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
