Multiple 1131 aps without controller
pcpolofnw
Community Member
We are setting up 7 1131aps and 1 1310 outdoor ap without using a wan controller. This should work just fine correct as long as we set them up with the same SSID and WEP key?
matthiasgoodman
Level 3
Level 3
This should work fine. You may want to set them up with WDS, since that would give you better control over roaming, etc.
