02-01-2014 11:11 PM - edited 07-05-2021 12:04 AM
Dear Team,
I am configuring air-sap2602 and created multiple ssid but its broadcasting only one ssid instead of multiple.Any one can help me?
Solved! Go to Solution.
02-02-2014 12:25 AM
Hi Waqas,
You may be missing "mbssid guest-mode" command under SSID configuration & "mbssid" command under radio interfaces. Since it is multiple SSID you require this.
Here is a sample configuration of two SSID (WLAN-1 with vlan 7 & WLAN-2 with vlan 😎 & AP management (on vlan 10). Security configuration used WPA2/AES with PSK
hostname AAP1
dot11 ssid WLAN-1
vlan 7
authentication open
authentication key-management wpa version 2
wpa-psk ascii WLAN-1-KEY
mbssid guest-mode
dot11 ssid WLAN-2
vlan 8
authentication open
wpa-psk ascii WLAN-2-KEY
mbssid guest-mode
interface Dot11Radio0
encryption vlan 7 mode ciphers aes-ccm
encryption vlan 8 mode ciphers aes-ccm
ssid WLAN-1
ssid WLAN-2
mbssid
station-role root
interface Dot11Radio1
ssid WLAN-1
ssid WLAN-2
mbssid
station-role root
interface Dot11Radio0.7
encapsulation dot1Q 7
bridge-group 7
interface Dot11Radio0.8
encapsulation dot1Q 8
bridge-group 8
interface Dot11Radio0.10
encapsulation dot1Q 10 native
bridge-group 1
interface Dot11Radio1.7
bridge-group 7
interface Dot11Radio1.8
bridge-group 8
interface Dot11Radio1.10
bridge-group 1
interface GigabitEthernet0.7
bridge-group 7
interface GigabitEthernet0.8
bridge-group 8
interface GigabitEthernet0.10
bridge-group 1
interface BVI1
ip address 192.168.10.254 255.255.255.0
ip default-gateway 192.168.10.1
Here is AP connected swtichport configuration. SVI configuratoin & DHCP configuration to be there (not shown here)
**** AP Connected Swtichport *****
int g x/x
switchport mode trunk
switchport trunk native vlan 10
switchport trunk allow vlan 7,8,10
Rasika
**** Pls rate all useful responses ***
02-01-2014 11:30 PM
can you paste the config here , then only we can find the cause.
Reagrds
02-02-2014 12:25 AM
Hi Waqas,
hostname AAP1
dot11 ssid WLAN-1
vlan 7
authentication open
mbssid guest-mode
dot11 ssid WLAN-2
vlan 8
authentication open
mbssid guest-mode
ssid WLAN-1
ssid WLAN-2
mbssid
station-role root
ssid WLAN-1
ssid WLAN-2
mbssid
station-role root
bridge-group 7
bridge-group 8
bridge-group 1
bridge-group 7
bridge-group 8
bridge-group 1
bridge-group 7
bridge-group 8
bridge-group 1
interface BVI1
int g x/x
Rasika
06-19-2014 05:22 AM
Hi Rasika,
With mbssid guest-mode command both of wireless SSIDs work in guest mode? Can I use both of SSIDs in my internal network for two parties?
Thank you
Kind regards
Chamara
06-19-2014 05:28 AM
Hi Chamara,
Guest mode broadcasts the SSID and only one SSID can be in gueat mode.
To broadcast multiple SSIDs use mbssid guest-mode on each SSID.
Check the example:
http://rscciew.wordpress.com/2014/05/24/multiple-ssid-configurations-on-autonomous-ap/
Dont forget to rate helpful posts
06-19-2014 05:32 AM
Thanks for the reply Sandeep. But my question is are those two SSIDs can use as non guest wireless for my office use
thank again bro
Kind regards
Chamara
06-19-2014 05:37 AM
of course you can use both ssid of office use.
Its depends on your configuration.
