multiple ssid's same key ?
jherder78
Community Member
i am deploying (1) 1242ag as root-bridge with multiple vlans and ssids but have left the key the same for each ssid/vlan. the remote (4) 1242ag's will be configured as work-group bridges with 1 vlan & 1 ssid for each. The key will be the same on all devices.
Is this recommended? how would it be better set up? or is it fine this way.
ivillegas
Level 11
Level 11
Are you referring to the WEP key. Using this method is not scalable and also not secure. Use a authentication mechanism like EAP which will generate per session keys.
