Multiple ssid to 1 wlan
alan.blakege
On a wlc 5508-7.0.116, can I set up 2 ssids that map to one wlan/vlan/subnet. I thought you could but I don't have the means to test without breaking production.
My goal is this:
Ssid red open
Ssid blue wpa 2
But all clients on the same ip subnet
Ab
Sent from Cisco Technical Support
George Stefanick
Absolutely .. I do it all the time for testing
__________________________________________________________________________________________
George Stefanick
George Stefanick
BTW -- Welcome to CSC, notice its your first post! If this helps please mark the question as answered as it will help others if they have a similar question.
alan.blakege
Glad to know. Thanks
Sent from Cisco Technical Support Android App
