Multiple SSIDs? 40bit WEP and 128bit WEP?
jpigott
Is it possible to have one SSID use a 40 bit WEP key and another SSID use 128bit?
I have some older AIR-PCM340 cards that only have 40bit encryption?
Jeff
kmarrero
Level 4
Level 4
You should be able to set up the multiple SSIDs on VLANs to use different WEP. Read over the section "VLAN Security Policy" on the following document. http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/accsspts/ap350scg/ap350ch4.htm#1036065
