09-07-2005 01:15 PM - edited 07-04-2021 11:06 AM
Hi Everyone,
We have some 1200 series APs (802.11b only) and they have multiple SSIDs configured (#1 and #2). Each SSID is on a separate VLAN and the switchport is a trunk port.
For some reason, users only are able to connect to SSID #2. If they remove the connection for SSID #2 so as to only connect to SSID #1, no connections are able to be made wirelessly.
Can someone help point me in the right direction as to solving this?
Pete
09-13-2005 10:34 AM
The VLAN number must match the Native VLAN configured on the switch.For further information verify the following URL:
09-13-2005 12:42 PM
Thank you for the reply. What is interesting is that on one CAT2950 switch, we have 3 access points configured. All 3 switchports are configured the same exact way and only one access point is problematic. For AP#1 and AP#3, we connect to the desired SSID just fine, for AP#2, we connect only to the SSID that we wish to retire, even when SSID#1 and SSID#2 are configured (just like the AP#1 and AP#3).
Pete
