Multiple VLANs per SSID with local switch
william.m
Is it possible to use an 'AP Group' or 'Interface group' to assign multiple VLANs to a WLAN when remote, h-reap APs are in local switch mode?
If not, is there a way to overcome 500 maximum host per VLAN when APs are local switching?
Thanks!
Viten Patel
dont think its possible...
I donno if the following config will even work but u can have the hreap APs connected at the remote site to map to different vlans...
Example:
AP1 -- ssid 1 --- vlan 10
AP2 -- said 1 --- vlan 11 and so forth..
Sounds crazy but i ll have to ponder on this a bit more.. Need a pen and paper to draw a quick topology :)...
