My AIR-LAP1142N-A-k9 doesn't join to WLC 2504
usamaaboodi
I have two AP with light weight AIR-IOS version ( c1140-k9w8-mx.152-2.JA) and one WLC 2504 with AIR-IOS (7.6.130.0) .
and I configured everything right but still the AP tried to connect to WLC and I get these errors from AP console
*Jan 1 00:21:17.999: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 1 00:20:13.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.29.100 peer_port: 5246
*Jan 1 00:20:13.116: %PKI-3-CERTIFICATE_INVALID_NOT_YET_VALID: Certificate chain validation has failed. The certificate (SN: 7B6171040000000754F6) is not yet valid Validity period starts on 09:28:20 UTC Nov 6 2015Peer certificate verification failed 001A
*Jan 1 00:20:13.117: %CAPWAP-3-ERRORLOG: Certificate verification failed!
*Jan 1 00:20:13.117: DTLS_CLIENT_ERROR: ../capwap/base_capwap/capwap/base_capwap_wtp_dtls.c:447 Certificate verified failed!
*Jan 1 00:20:13.117: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 192.168.29.100:5246
*Jan 1 00:20:13.117: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.29.100:5246
*Jan 1 00:20:13.118: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 3 combination.
please any advice
thanks
2 Accepted Solutions
Scott Fella
You sure you set the time properly on the controller?
-Scott
-Scott
Yup, just as suspected.  The time-and-date of the controller is incorrect.
Without a correct time and date, the AP won't join.
6 Replies 6
Leo Laohoo
Post the complete output to the following commands:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time; and
3.  AP:  sh version
1- AP sh Version
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 15.2(2)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 23-Aug-12 03:15 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA1, RELEASE SOFTWARE (fc1)
APccef.4807.2bba uptime is 18 minutes
System image file is "flash:/c1140-k9w8-mx.152-2.JA/c1140-k9w8-mx.152-2.JA"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1142N-A-K9 (PowerPC405ex) processor (revision A0) with 81910K/49152K bytes of memory.
Processor board ID FTX1537K3UB
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
LWAPP image version 7.3.1.73
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: CC:EF:48:07:2B:BA
Part Number : 73-12836-03
PCA Assembly Number : 800-33767-03
PCA Revision Number : A0
PCB Serial Number : FOC15344PN4
Top Assembly Part Number : 800-33775-02
Top Assembly Serial Number : FTX1537K3UB
Top Revision Number : A0
Product/Model Number : AIR-LAP1142N-A-K9
Configuration register is 0xF
2- WLC:show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.130.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_00:35:c4
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.29.100
Last Reset....................................... Power on reset
System Up Time................................... 0 days 0 hrs 3 mins 33 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... US - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +33 C
External Temperature............................. +36 C
Fan Status....................................... 3200 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 80:E8:6F:00:35:C0
Maximum number of APs supported.................. 5
3-WLC: show time
Time............................................. Sat Jan 1 00:37:54 2000
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
NTP Polling Interval......................... 3600
Index NTP Key Index NTP Server NTP Msg Auth Status
1 0 192.168.29.254 AUTH DISABLED
Yes, it was incorrect time, thanks for your advice!
Thank you for taking the time to rate our posts.  :)
Scott Fella
-Scott
-Scott
