Nac on wireless lan controller
ittichai_a
Level 3
Level 3
Hi sir;
I have some problem in implement Nac on wireless lan controller.
- I using ACS version 4.0
- My laptop already install CTA and Aegis secure for authentication.
- Controller I have already did it.
First, time I had tried to authenticate EAP-FAST before do NAC. That working as well but after i apply policy nac on ACS, I cannot authenticate EAP-FAST anymore. Logging show "EAP type do not configure" in ACS server, but I had done to configure it.
So, now i don't have idea to implement it, so, if anyone have some suggestion or some ducument, please help me.
dominic.caron
Level 11
Level 11
The problem might be that Cisco's CTA is already included in aegis 4.0 client. I know there is some version problem if you install the standalone CTA. It's was documented on aegis 4 release notes.
segopala
try to increase the eap timeout on controller
set all the value to maximum limit ; let me know if this resolves the problem
(GUEST_F_4-4400) >config advanced eap ?
identity-request-timeout Configures EAP-Identity-Request Timeout in seconds.
identity-request-retries Configures EAP-Identity-Request Max Retries.
key-index Configure the key index used for dynamic WEP (802.1x) unicast key (PTK).
max-login-ignore-identity-response Configure to ignore the same username count reaching max in the EAP identity response
request-timeout Configures EAP-Request Timeout in seconds.
request-retries Configures EAP-Request Max Retries.
Seema
