NAC problem with Samsung Galaxy Grand (Android)...!!!
Nithin Jacob
I tried accessing wifi though my Android mobile in my college, which is NAC installed. The mac address of my device was successfully added to the portal, but I'm not able to connect my device to the respective wifi network.
Can anyone suggest what's the problem.
Amjad Abdullah
It is probably issue with your NAC config.
If issue with all android devicea then look into this:
https://supportforums.cisco.com/message/3889346#3889346
Amjad
Rating useful replies is more useful than saying "Thank you"
Thanks a lot Amjad for your reply.
But I've configured other Android phones, and they are working fine.
Is this issue related to the newer verison of Android...??
I don't honestly know.
If you connects with no L2 security, then I suggest you move your discussion to AAA, identity and NAC sub-forum in security forum.
Amjad
Thanks Amjad.
If u come to know something about this issue, please inform me.
Nithin
