Native VLAN Help!!!!!
tlchant
Hello I setup an AP with 3 VLANs VLAN1=native, VLAN2=VoIP, VLAN3=Data. VLAN2and3 are working greate however the native VLAN which the AP resides I can not ping or web browse to the AP. I can use a cross over cable to make a connection. The native VLAN has an SSID with association=0. I want to setup the native VLAN so that it can only be accessed for administration over the copper network. Any help would be great. I am oconnecting to a 2950 which is then connected to a 6509.
wong34539
Level 11
Level 11
You can have only one VLAN without any encryption also try not to associate the Native VLAn with the native SSID.
