VLAN Transparent is disabled
Ethernet Bridging is enabled
Only the native vlan is not passing, cannot ping between 10.1.1.0/24
RAP tested with normal port as well as with trunkport
MAP tested with trunkport
Tested with WLC4404 7.0.252.0 and WLC2504 7.4.140.0 / 7.4.130.0 / 7.0.252.0
Topology:
Thank You!
