NCS associated with controller problem.
Ahmed Ayaad
Level 3
Level 3
Dears,
HI
I have PI 1.3  deployed  on ESXI 4 (in HP Blade)  with ip 192.168.220.230 after that i deployed virtual controller on the same blade with ip 192.168.220.232 the HP Blade connected to multilayer switch and i can ping from the NCS to Controller but when i try to add the controller on NCS i see the following error"Add Device Failed! Device already exists in the current domain"), how i can solve this problem,
Knowing that i configure on the controller the Community Name, IP address 192.168.220.230, Ip mask 192.168.220.232 ,Access mode ReadWrite, and status enabled.
Also configured Interface vlan(192.168.220.1) and the Blade access this vlan.
Scott Fella
Might want to look at this link.
https://supportforums.cisco.com/docs/DOC-27761
-Scott
Sandeep Choudhary
adding to scott...
Check under Configure - Unknown Devices
