NCS Prime: Traffic Stream Metric Reports not beeing populated
alex.dersch
Level 4
Level 4
I have a VoWLAN where i'd like to get Traffic Stream Reports, but no reports generated. I get the message No data matches the specified criteria for the report.
Any idea, i configured the Voice Media Parameters like this.
any ideas?
thanks
Alex
ramkris2
Alex,
Can you verify if the 'Traffic Stream metrics' task is enabled & running successfully ? It can be seen from the Administration --> background tasks page.
What version of code are the WLC's running ?
Is the data presented directly on the WLC ?
Ram.
Hi Ram,
The data is also not presented on the Controller and the code is 7.0.220.0.
In the NCS the TRaffic Stram Metric is enabled and running all 5 minutes.
regards
Alex
Hi Alex,
Then it won't be a NCS/reporting issue as the data is polled from the WLC's. I would suggest opening a TAC case against the Controller to troubleshoot it further to run debugs & such.
Ram
