NCS Startup Issues
ABM Networking
Frequent Visitor
Frequent Visitor
I have insatllaed Prime NCS on a physical server, the install on the box went smoothly.  I tried to logonto the webpage, which was unavailable?  did an NCS Status on the box and had the following output:
ABM-PRIME-NCS/admin# ncs status
Health Monitor is running, with an error.
failed to start NCS on startup Health Monitor
Reporting Server is running
Ftp Server is running
Database server is running
Tftp Server is running
Matlab Server is running
NMS Server is stopped.
SAM Daemon is running ...
DA Daemon is running ...
Syslog Daemon is running ...
status
Has anyone experienced the same issues?????
thanks
nev
Scott Fella
Make sure you have meet the requirements for the ova you use. Hard drive space is important.
Have you tried rebooting the VM. Also others have had to issue the following to get the services to start.
ncs stop
ncs db reinitdb
ncs start
-Scott
Scott Fella
ncs stop
ncs db reinitdb
ncs start
-Scott
Scott
Thanks for that worked a treat, there is however when I input the password I get a blank screen??
thanks
nev
Scott
Scratch that I have got access now.
thanks
nev
