Need a wireless bridging solution
Michael Locke
Frequent Visitor
Frequent Visitor
                   With the short haul 1300 series WL Br EOS and the Exalt series overkill in range and price I need a short haul (<400m) with a yagi type antenna (directional) to shoot between buildings. Is there an AP solution for this distance that has a min 54MB thru put and doesn't break the bank?
Scott Fella
You can use any Cisco AP that has an external antenna ports.  Now if you get 54mbps, depends on the distance and if you have interference between the link.  Now using an indoor AP, you understand that youhave to either mount these inside or in an enclosure that might have a heater/fan for the environment.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
