Need help configuring a local IP to a Public IP
nickospot
Hello
I currently am trying to host a local ip 10.x.x.x but intend to point it to a public IP 41.x.x.x. The Global DNS has been done
I have attempted to do this via natting the network object which didn't work
Also I tried natting on the interfaces but still didn't work.
The host can be reached locally but not from the Internet.
Need help doing this, am used to GUI on cisco 5500
balaji.bandi
here is the guide to setup one :
https://www.petenetlive.com/KB/Article/0000691
If you arleady done and not working, can you post the running config to have look and suggest better way to fix the issue.
BB
nat (outside,inside) source static any any destination static 41.x.x.x 10.x.x.x no-proxy-arp
