01-08-2025 05:17 AM
Hi, I need help for configuration of access point C9105 AXI-D
01-08-2025 05:28 AM
What are you trying to do? Join the AP to a WLC or setup the AP as EWC ?
01-08-2025 05:42 AM
I have total 13 nos. of this model.i want to make one as controller and remaining it's secondary.
01-08-2025 05:59 AM
Sounds like a plan. You need to setup two EWC amont those 13 you have. Then, 11 will be only normal AP. One EWC you set as primary, automatically the other EWC will be the secondary.
There will tons of guide if you search and very detailed videos on youtube on how to setup EWC.
You may need to prepare a TFTP server on your PC and add Access Point image on the TFTP directory as the EWC does not provide images to the Access Points.
But, all those details you can find on the guide. Read it carefully and let me know if you stuck at some step.
01-08-2025 05:44 AM
https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/17-13/config-guide/ewc_cg_17_13/overview_of_the_controller.html <<- this for EWC
What you meaning secondary can you more elaborate?
MHM
01-12-2025 07:28 AM
@MHM Cisco World https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/17-13/config-guide/ewc_cg_17_13/m_ewc_high_availability.html
01-12-2025 07:30 AM
I want to clear he want other AP to be standby ??
MHM
