Need help in Accessing the used Access Points or Production APs
Hi Team,
I just added an AP to my WLC through  "Capwap ap controller ip XX"  by using Default Username and Password..."Cisco and Cisco".
1. But is it possible to access my LAP through Telnet / SSH/Https after adding it to WLC. and how?
2. I am unable to access my LAPs after adding it to my WLC with default username and password. What do I need to do for accessing it remotely.
Please help me friends.
Scott Fella
Just to add... All configuration is done on the WLC after an access point has joined. If you want to access the AP, then you can only telnet or ssh as there is no GUI. Here is a guide that will explain how to setup that piece:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-0/configuration-guide/b_cg80/b_cg80_chapter_01100111.pdf
-Scott
-Scott
Thank you Philip.......
Scott Fella
-Scott
-Scott
It does clear my all doubts....... Thanks a lot scott... :-)
