11-14-2002 02:15 AM - edited 07-04-2021 08:21 AM
Hi Guy,
How to over come this problem, Currently using W2k Professional via IE Version 6 SP1 "Invalid Administration Connection.This machine cannot be used for administration of CiscoSecure ACS v2.5 for Windows NT. Contact the System Administrator for access. "
11-20-2002 08:34 AM
This problem is usually seen when the browser has a proxy server configured. To fix it, disable proxy server completely and then bring up the ACS administration screen.
11-20-2002 11:35 AM
You can not install ACS2.6 on Win2K Prof. This is designed to work with either Win NT or Win2k Server/Advanced Server, although ACS 2.4 will work will Win2k Prof; and ACS v1.0 will work with Win2k Prof.
But 2.6 needs server to work with.
Therefore, you have to install the ACS on a machine running Win2k Server or Advanced Server; no other solution.
Anwar Qureshi
Excel Computer Center
