Need Help regarding WAP
souravpal
Community Member
%CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
Getting error in cisco LAP1142 ..
After  adding IP address and controller IP address. its showing another error...
Translating "CISCO-LWAPP-CONTROLLER"...domain server (255.255.255.255)
Then
*Mar  1 00:13:15.890: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
ernet0, changed state to up
ernet0, changed state to down
Yahya Jaber
what method are you using in order the AP will discover the WLC?
i.e.
%CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip this one for DHCP 43
Translating "CISCO-LWAPP-CONTROLLER"...domain server (255.255.255.255) this one for DNS
others are normal happens regarding the join.
if you want, you can configure the WLC and the IP statically.
capwap ap ip address ip_address
capwap ap ip default-gateway default_gateway
capwap ap controller ip address ip_address
hope it helps.
