Need help setting up second WAP121
adrianlee1
Community Member
My IT guy quit, and I am in desperate need of setting up second WAP121.  My first unit was setup by my IT guy, and I have used the Cisco initial setup, but everytime I hi save, it is saying that the function is disabled.  So, I cannot setup the second WAP121.
Do I need to do the RESET to change the password and ADMIN privillage since I do not know the userid and password?  I cannot get hold of my IT guy anymore.
Thank you.
Adrian
Moin Ilyas
Level 8
Level 8
Yes, I believe you need to reset to get the Admin privileges.
