Need help with Cisco AP c1200 configuration to access external DHCP server
Harsha A.
Hello All,
I have a Cisco AP c1200 (IOS AP) in our network and all these days it has been using a DHCP pool (configured in the IOS) for assigning IP address to the client.
Now, I have created a DHCP server (Windows Server 2008) to assign clients an IP address.
I have a Cisco ACS that is being used for authentication and accounting purpose.
I have been going through various posts and I did find something called DHCP option 43 configuration for LWAP but I would like to know in detail how to configure this option on my DHCP server so that clients who connect to the AP can get IP address from the DHCP server.
Note: I do not have a Wireless LAN Controller in my network and most of the configurations involve WLC IP to be included in the HEX value.
Kindly help me out.
Harsha
5 Replies 5
Scott Fella
Option 43 is only used for the access points to find the WLC from the dhcp address the ap gets. For the clients to get an IP address from dhcp, you need an IP helper on the clients subnet BVI interface.
http://www.cisco.com/en/US/docs/ios/12_4t/ip_addr/configuration/guide/htdhcpre.html
-Scott
Scott Fella
Here is a doc in case you need to use multiple vlans.
https://supportforums.cisco.com/docs/DOC-14496
-Scott
Hello Scott,
I did follow the guidelines and added ip helper-address command to the int BVI1.
But right now when I try to connect to the Access Point I do see that my wireless keeps saying Attempting to Authenticate.
I checked our Cisco ACS and in the logs I found "Invalid message authenticator in EAP request".
Then I did search for that message here on Cisco.com and found that it could be because of the incorrect shared key between Access Point and ACS.
Then I have changed the shared key on both AP and ACS and saved config on the AP and tired a reload but still I get to see the same error message on the Failed Attempts log file in the ACS.
Need some suggestions on this error.
Harsha
Scott Fella
Your policy for authentication must be wrong. How do you have it configured?
-Scott
Hello Scott,
This is the show run output.
ip domain name mydomain.com
ip host DHCPSERVER 10.20.9.56
ip name-server 10.20.9.48
ip dhcp excluded-address 10.20.9.1 10.20.9.210
ip dhcp-server 10.20.9.56
ip dhcp-client default-router distance 1
--More--
aaa new-model
aaa group server radius rad_eap1
server 10.20.9.30 auth-port 1645 acct-port 1646
aaa group server radius rad_acct
aaa group server radius rad_mac
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods1 group rad_eap1
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid SSID
    authentication open eap eap_methods1
    authentication network-eap eap_methods1
    authentication key-management wpa
    guest-mode
short-slot-time
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
ip address 10.20.9.13 255.255.255.0
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.20.9.9 255.255.255.0
ip helper-address 10.20.1.56
no ip route-cache
ip default-gateway 10.20.9.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging snmp-trap emergencies
logging snmp-trap alerts
logging snmp-trap critical
logging snmp-trap errors
logging snmp-trap warnings
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.20.9.30 auth-port 1645 acct-port 1646 key 7 (KEY)
radius-server vsa send accounting
bridge 1 route ip
Harsha
