need help
ish000001
Community Member
how can i disable the remote login on a rv082 router or close port 60443?
Sandeep Choudhary
enable firewall;
disable: SPI, DoS, Block Wan, Rem. Management
and remove all custom Access rules (Restore to default rules).
probably enable the firewall and set a pass-all rule.
It is a bit odd, but it seems to be the only way to disable remote management.
Info:
From the manual of recent version, where screenshots of v3 with  recent firmware are presented, it seems that they have fixed the  behavior.
By default if firewall is disabled, also remote management.
Hope it Helps.
