need help
ShwetaAswal
Community Member
I want report about uptime and downtime of all APs .where to find ?
aleabrahao
Meraki Community All-Star
Unfortunately the only way to achieve this is to customize using APIs and programming.
The API endpoint, getOrganizationDevicesBootsHistory (GET /organizations/{organizationId}/devices/boots/history), returns a list of all boot records for devices in the organization. If a device is currently online, you can use these records to derive uptime by subtracting the current time with the bootedAt timestamp. You can use API endpoint getOrganizationDevicesBootsHistory, providing the history of your device boots, and getOrganizationDevicesAvailabilitiesChangeHistory, providing the change history of your device availabilities, together for a more complete view.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
7 Replies 7
aleabrahao
Hi you can check this on Network-wide > Monitor > Devices > [Select AP] or Network-wide > Monitor > Event Log and filter by Device Boot or Connectivity events.
Device Uptime - Cisco Meraki Documentation
Hi thanks,
But i need all APs uptime/downtime together not individual.
aleabrahao
The endpoint getOrganizationDevicesBootsHistory support only 730 days back.
What if the device is on more than 2 years?
I know it is very rare, but I need to cover all the cases.
I there a way to get the uptime in this case?
Shubh3738
Level 6
Level 6
On pages like Wireless > Access Points, use the Export as CSV option. But actually, you need on this report?
through wireless> Access Points ,i only download an individual AP's report but i need uptime/downtime of All APs .
Philip D'Ath
Now quite what you want, but what about the Wireless Health report?
