Need some help
pslph2012
Community Member
Hi, I am attempting to configure a Aironet 1042N AP From my understanding it does not have an IP out the box. I attempted to access the console which I can view it booting up but then it hangs on the following:
*Mar  1 00:14:23.027: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1040 Software (C1140-K9W7-M), Version 12.4(25d)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 11-Aug-11 02:58 by prod_rel_team
*Mar  1 00:14:23.028: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:14:23.987: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:14:24.002: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:14:24.002: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:15:45.717: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:15:47.717: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:15:48.717: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Mar  1 00:15:55.717: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:16:04.898: %LINK-3-UPDOWN: Interface BVI1, changed state to up
*Mar  1 00:16:05.898: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
It does nothing after that just hangs I am unable to obtain a command prompt
Can anyone give me some insight as why this might be.
Thanks ahead of time
Stephen Rodriguez
With the AP you have I make sure that you have flow control set to none. After that you should be able to access the console
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
