09-22-2019 09:09 PM - edited 07-05-2021 11:02 AM
Dear Members,
I need to upgrade 5508 from 7.6 to 8.3.xx. Do i need to upgrade FUS image latest to 1.9. Attached is the screenshot regarding the current SH SYSINFO command output.
09-22-2019 09:50 PM
Hi Kashif,
Cisco recommand to upgrade the FUS version to 1.9 specially if you want to run the 8.3 code on WLC.
https://software.cisco.com/download/home/282600534/type/284364857/release/1.9.0.0
Regarding Software upgrade: First you need to move from 7.6 to 8.0 version then to 8.3.150.0(Direct upgrade from 7.6 to 8.3.150.0 is not possible)
https://software.cisco.com/download/home/282600534/type/280926587/release/8.3.150.0
Dont forget to rate helpful posts
09-23-2019 12:20 AM
09-23-2019 12:36 AM
- Too blurred, please provide good quality.
M,
09-23-2019 01:54 AM
09-23-2019 12:54 AM
currently you are running:
Bootloder version: 1.0.1
FIRV: 6.0.102.0
FYI: FUS contain many other parameters..
onc you upgrade to FUS version 1.9 you will see....like this
* Field Recovery Image is upgraded from 6.0.102.0 to 7.6.101.1
* Bootloader is upgraded to 1.0.20
* Offline Field Diagnostics is upgraded from 0.9.28 to 0.9.35
09-23-2019 01:58 AM
09-23-2019 02:48 AM
yes upgrdae FUS and then software. But make sure you take a downtime of 1 hour as FUS image alone will need 45 min.
Dont forget tot rate helpful posts
