Airplay wired to wireless not working
rlaudiano
Hi, need help to understand what my problem is? Airplay situation is as follows:
  1. Wireless to wireless devices - working fine
  2. Wireless to wired devices - working fine
  3. Wired to wired devices - working fine
  4. Wired to wirelss - NOT working
Any advise on what seems to be the problem? Thanks in advance
Cisco 3600 access points, WLC 2504
Sandeep Choudhary
Did you enable multicast on the wired side ?
Cisco WLC for Wired to Wireless mDNS and Bonjour:
https://packetu.com/2018/10/31/cisco-wlc-for-wired-to-wireless-mdns-and-bonjour/
Also go through this guide:
https://www.cisco.com/c/en/us/support/docs/wireless/aironet-1100-series-access-point/113443-cuwn-apple-bonjour-dg-00.html
Dont forget to rate helpful posts
