network access on wireless
cghaderpour
Level 3
Level 3
we are planning to move from network access with pre-shared key to wpa-enterprise with meraki cloud authentication across a midsize company. I would like to get some guidance if someone has already done this.
TY
7 Replies 7
kYutobi
Level 11
Level 11
If should be really easy to setup if you're using Meraki for authentication and creating your user logins. I would just test it really quick by creating an SSID (hidden) if it's just you. Then try it there with a created user.
Enthusiast
aleabrahao
Meraki Community All-Star
Here is all that you need to know.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring__WPA2-Enterprise_with_Meraki_Authentication
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
Philip D'Ath
Meraki authentication may be challenging to maintain at the scale of a "mid-size" company.
Also check out the "Trusted Access" feature - but note this needs a Systems Manager licence for every user.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Trusted_Access_for_Secure_Wireless_Connectivity
Just curious @Philip D'Ath because I'm trying to guess your number 😁 "mid-size". Where would you stop scaling through Meraki authentication? I've usually done 40 but 20/20 split between networks.
Enthusiast
Philip D'Ath
I was thinking of 200 to 500 employees.
Creating separate accounts with a password not linked to their other systems will result in much work constantly resetting passwords (most likely a daily service ticket to resolve). And if they have multiple devices, every time that password is reset they'll have to re-enter it on the other devices that were working but which have now broken.
I think I would use Meraki Authentication for up to 20 users. How have you found the administrative effort using this approach with 40 users?
It's not too much of a burden since it wont move up from 40 but I definitely see your point when you say 200 to 500 😳😲😲. Wouldn't even suggest 😂
Enthusiast
BlakeRichardson
I manage just over 1100 users with 802.1x using a cloud based directory which works well for us.
Meraki Auth IMO would be fine for a small amount of users provided staff retention was good.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
