network discovery not posible with wireless conection
Any of you know why is not possibe to carry out a network discovery with wireless conection?
If I connect by cable I can discovered all the machines on my network.
Do I have to enable something in my WLC in order to do this?
regards
7 Replies 7
George Stefanick
Do you have peer to peer blocking enabled on the WLAN ?
Hi George,
thanks for your recommendation.
I'll try the option and then I'll tell you the results
regards
 On the controller for a default perspective there isnt anything that should block you from scanning other clients. However if peer to peer blocking is enabled, or if you have some type of ACL that could be an issue for scanning clients over wireless
Hi George,
After enable P2P Blocking  with Forward UpStream I can discovered the network :-)
regards
George Stefanick
Is peer to peer enabled on the WLAN ?
mohanak
Peer-to-peer blocking is configured on a per-WLAN basis and prevents clients on the wireless network from communicating with one another. By default, peer-to-peer blocking is disabled for new WLANs.
Hi mohanak,
thanks for your very clear explanation.
regards
