Access point Signal strength
Maurice Ball
Level 3
Level 3
Could someone please tell me how to configure my WLC 2504 to set the associated access points signal strength to maximum?
Ashish Chandra
You can set maximum power individually on each AP or you can set them globally to Power Level 1 which is the maximum power level by going to:
Wireless > 802.11b/g/n or 802.11 a/n/ac > RRM > Power Level Assignment Method > Fixed 1
Ashish Chandra
thanks for the help
Abhishek Abhishek
Please go through-
I have the same problem I have Access Point Cisco 1602I-T-K9 is set up, but
with a very weak signal, where I set to leave the strongest signal?
