Network Roaming using same IP address
gwbarnestx
Community Member
I am trying to deploy Mobile IP within a switch and router network with AP1230s to enable laptops to roam without changing IP addresses. Cisco configuration guides indicate that the CLIENT or Mobile Node must be able to roam. I cannot find out how to enable my MNs to register with a Home Agent. Or, is that necessary when you use Proxy Mobile on the AP?
mchin345
Level 11
Level 11
You can use the "Cisco Mobile Wireless Home Agent 2.0 " for this. You can find more information on this at
http://www.cisco.com/en/US/products/ps5940/products_installation_and_configuration_guide09186a008027a6c0.html
