11-10-2015 05:35 PM - edited 07-05-2021 04:12 AM
Hello All,
Opened a TAC case for the above issue. This is specific for customers who are using mobility anchoring solutions with their customers or partners.
Cisco created a bug ID for this issue and are currently investigating. Kindly note this is not specific to guest anchoring.
Why enable new Mobility ?
New mobility (CAPWAP) is required when Native wireless controllers have to establish a mobility tunnel to Cisco IOS controllers (5760, 3850 or 3650)
Background: We were using old mobility (EOIP) tunnels to offer wireless service at 3rd party sites that has foreign controllers.
There is no isse on old mobility.
Issue:
When new mobility is enabled (CAPWAP) we have to enter the public and private IP address for mobility tunnels to come up.
At the foreign controller end (both end NAT'ed IP not tested) , if the IP address is Nat'ed to public IP address, when the client try to connect the clients do not receive the IP address as they get stuck in DHCP_REQD state.
Work around:
1)This issue is not noticed if controllers at both ends are using Public IP address or only private IP address. The clients receive an IP address and works as desired.
2)Enable Old mobility (EOIP) if CAPWAP mobility is not mandatory.
Recommendation to Cisco wireless BU :
Cheers,
Devaiah N K
03-26-2018 11:56 PM
Cheetah-flex: local auth client "Policy Manager State" is DHCP_REQD
CSCux00803
Description
Symptom:
sh client details shows policy manager as DHCP_REQD
Conditions:
wlan is configured to be local auth
Workaround:
none
