10-31-2011 09:31 AM - edited 07-03-2021 09:00 PM
I want to purchase a new system comprised of 19 APs across a WAN consisting of 5 locations. I have a couple of questions. Is there any advantage of going with the 5500 series controller over the 4400 series? I want b, g and n coverage. Other than that, I need basic wireless and possibly a mobile phone or three. We are in existing Cisco networks with 3560 PoE switches in place and have a Cisco VOIP phone system. Traffic and number of users is expected to be light. We also have 2800 routers at each location.This will be in a government facility with high security standards also.
I'm currently looking at
Cisco 4402-25 controller
Cisco Aironet 1252 AG controllers
Is this compatible and will it do what I want?
Is there a cheaper AP that will do b, g and n?
Please chime in with any other advice.
Solved! Go to Solution.
10-31-2011 09:36 AM
Joe,
yes that would work, but the 1252 requires a higher power requirement than the standard 802.3af, and the 4402 is now EOS.
So I would recommend you go with:
WLC 5508-25
Cisco AP1142, a/b/g/n , internal antenna and 802.3af power
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
10-31-2011 09:36 AM
Joe,
WLC 5508-25
HTH,
Steve
10-31-2011 03:16 PM
1250 is EoS too.
12-06-2011 11:22 AM
Thanks to both of you for taking the time to answer my questions. That was very helpful. Still fighting the budget battle but that was the informatin I needed to proceed.
12-06-2011 02:13 PM
You can choose the 1042 WAP. It's cheaper than the 1142 but it will only support 2 x 3 MIMO (1142 will support 3 x 3 MIMO). Like the 1142, the 1042 support 802.11 a/b/g/n.
