Nin-standart mesh deployment scheme
Hello! Would like to ask:
is it possible to implement MESH design when there are two or more RAP in the same MESH group? Does it have any limitations?
3 Accepted Solutions
Sandeep Choudhary
Yes you can have multiple RAPs in same Mesh Group.
***All RAPs have the same bridge group name to allow failover from one RAP to another.
Don't forget to rate helpful posts
Go through this guide, it may help:
http://www.cisco.com/c/en/us/td/docs/wireless/technology/mesh/8-0/design/guide/mesh80.html
Dont forget to rate helpful posts
May want to be careful with anything load balancing on mesh. I find it best to manually configure and do your own balence with preferred parent.
Sandeep Choudhary
Thanks for your reply! Is it only failover feature or load balancing is avalaible? Could you please suggest any design guide?
