No licenses in use - Cisco C9800 WLC controller
wilson-leong
I would like to seek from anyone advise about the licensing in Cisco C9800 WLC controller how's it work actually?
As I have found that the license not activated in my current Cisco C9800 WLC controller past two days ago, this incident happened when the power maintenance has been done in my office building past two days ago and the controller was powered off about few hours during the power maintenance down time.
Then, the controller is power on back after the maintenance was done and noticed that the licensing not showing anymore and indicate the license not in use as shown below.
Could I know whether is it need to take some time for the controller to connect to Cisco Smart Licensing Portal to activate back the license? if yes, how long the duration will be taken? As it seems more than 2 days then the controller is power on and up currently but the license still haven't activated yet.
Appreciate if anyone can advise for this case.
Thanks.
Wilson Leong
@wilson-leong hi, seems like you are hitting bug. what is the firmware version in WLC? if its latest recommend version, i suggest you two options.
1. try to reregister device with smart license (assume your wlc using smart license)
2. open TAC support case if non of above workaround works.
Good luck
KB
marce1000
  - Checkout : https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/217348-configure-troubleshoot-catalyst-9800-w.html
 The following commands can also  help for troubleshooting :
            show license air entities summary
            show license status
            show license summary
            show license tech support
            show tech-support license
 M.
wilson-leong
Hi Kasun Bandara and Marce,
Thanks for your kind feedback and advise.
Anyway, for your info this issue has been resolved. As I have noticed that due to the one of the switch was having issue that caused the controller that connected to the switch don't have the internet access to re-activate the license.
After rebooted the switch, the internet connection was resume back and the license was reflected and updated currently as well.
Anyway, thanks for both of your kind feedback.
