Noob Cisco Wireless Question
singtoeil
I just set up a Cisco 5508 WLC and a 3702 AP. The AP is in flexconnect mode. Both the link to the WLC and AP are trunks. Both are using VLAN 255 as their managment ip. Facing the AP I used "switchport trunk native vlan 255", and am able to reach it over its management ip.
My question is, how do I set up an SSID to use VLAN 100 (or any other vlan)? When I go in to my AP, under the flexconnect tab, VLAN Mappings, it shows the wlan, but says its a "Centrally switched wlan". Its grayed out to specify which vlan it is in.
On "WLAN VLAN Mapping" change to "Make AP specific" The SSID need to be in flexconnect mode. On the Advanced tab of the WLAN, make sure it is flexconnect.
Then, add 100 on the VLAN ID field.
