Not able to access controller using management interface
wajahatkhan
Community Member
Dear All,
I configure IP address on the management interface port 1 of 5508 controller when i connect it direct to my laptop i can't ping or access controller from my laptop even i connect through layer 2 switch still i can't not.
IP Address of management interface : 10.21.0.50
Laptop IP Address : 10.21.0,51
3 Accepted Solutions
Change your switch config to this
interface GigabitEthernet1/0/24
description *** connected to WLC ***
switchport mode trunk
-Scott
Scott Fella
Basically this is what you need to issue
config t
interface GigabitEthernet1/24
no switchport trunk native vlan 10
-Scott
Scott Fella
When you define the native vlan 10, you essentially are not tagging the vlan 10. So if you keep the native vlan 10 command, you need to change the manager interface vlan on the WLC to zero (0).
-Scott
13 Replies 13
Scott Fella
You need to make sure that the manager interface is untagged. The vlan should be set to zero (0). Then you will be able to ping and access the WLC.
-Scott
Thank for your reply...
Management interface is untagged and i can access using serive port but not through management interface
Scott Fella
Now best practice is to not connect you laptop to the WLC. You know that though... So eventually you will connect it to a switch and them you will want to actually tag the vlan. So if the WLC managing is on vlan 50 let's say, you will change the manager interface vlan to 50. Hope this helps:)
-Scott
i tried this as well i connect my WLC to the through switch and i tag WLC interface to vlan 10 and also configured my switch interface which is connected to wlc to configured as vlan 10 and also my laptop in vlan 10 still not working
The port the WLC connects to should be a trunk port not an access port.
Please post the switchport configuration the WLC is connected to and the one your laptop is connected to. Don't forget the show interface summary from the WLC.
-Scott
Scott Fella
If your WLC is connected to a switch, you must make sure it's a gigabit switch. The WLC is only gigabit not 10/100/1000.
If you connect it to a switch, make sure it's a dot1q trunk port. Now connect your port on an access port assigned to that same vlan as the WLC manager interface is on.
-Scott
Scott Fella
Please post from the CLI show interface summary
-Scott
Interface Name Port Vlan Id IP Address Type Ap Mgr Guest
management     1      10       10.21.0.50 Static Yes No
service-port      N/A   N/A      192.168.102.11 Static No No
virtual               N/A    N/A     192.168.167.11 Static No No
PC on the switch:
interface GigabitEthernet1/0/23
switchport access vlan 10
switchport mode access
WLC on the swich
switch model is 2960S
-Scott
Scott Fella
config t
-Scott
Scott Fella
-Scott
Now i reach my home let me try in the morning and i will update you
No problem. Keep me posted.
-Scott
