NPS Wireless authentication based on user group
kevinjapto
Visitor
I have two SSID : 1. SSID-NPS and 2. SSID-NPS2
both of them is using nps radius server.
I want to make the rule
1. only groups 8021x can connect SSID-NPS
2. only groups 8021xb can connect to SSID-NPS2
i have already using called station ID, but only rule 1 is running well,
when i test SSID-NPS2, the user in group 8021x still can connect to that ssid.
Note : I only using eap-peap method (connect using username and password from active directory)
below is the configuration of NPS server. please correct if i missing the configuration
Rasika Nayanajith
I think it is because your two SSID names are not unique. If you use distinguish SSID names ( SSID-NPS-1 & SSID-NPS-2) you should be able to filter using called-station-id
Rasika
JPavonM
Terhe should be a condition to match "Called Station ID" with the value of the BSSID like ".*.:SSID-NPS" or ".*.:SSID-NPS2" (without the quotes) for every Machine Group you want to split.
-Jesus
*** Please Rate Helpful Responses ***
Instead of solving this problem I would first think about your environment. Typically it does not make any sense to "waste" two SSIDs if both use the same authentication-methods to the same authentication-server. It's likely that you only need one SSID.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
I agree with Karsten here... you can achieve this by rules and vlan assignments. However, if you still want to go ahead and figure your scenario out, you need to use a better regex. Your ssid #1 overlaps with ssid #2 so you either can follow what Rasika mentioned and really make then unique or see if NPS takes standard anchor in regex.
^.*: SSID-NPS$
^.*: SSID-NPS2$
-Scott
