OEAP 602 with 2x Remote LAN Ports
alex.roth
I know the limitations for an OEAP 602 AP with 1 x Remote LAN port:
"Only four clients can connect to an OEAP600 series through a RemoteLAn port".
My question is know if If I´m  using 2  Remote LAN ports can I thne use 4 clients per port or not ?
Thanks for help.
Rasika Nayanajith
Hi Alex,
I think client limitation is per Remote LAN. If you want to use two ports as remote-lan you have to assign two different remote LAN for port#3 & port#4.
I haven't test the limit of client in each remote-lan. This post may help you how to configure this dual-remote lan feature on OEAP602
http://mrncciew.com/2013/03/11/oeap-with-multiple-remote-lans/
Rasika
**** Pls rate all useful responses ****
Rasika Nayanajith
Hi Alex,
Rasika
Thanks for your informations.
