09-12-2011 08:35 AM - edited 07-03-2021 08:45 PM
Whats it "OfficeExtend support" in the 5500 WLC datasheet?.
I dont see nothing about this in the WLC configuration guide release v7.0.116.0..
Is this the same as OEAP?.
Is the OfficeExtended (or OEAP) supported on the 1140 APs?. If so where can I get a guide to configure this?.
Thanks.
Solved! Go to Solution.
09-12-2011 08:44 AM
Yes OEAP is office extends.
yes, it requires a 5508 to support office extends. A 4400, 2100 or 2500 will not support OEAP.
Here is a link to the config guide
http://www.cisco.com/en/US/products/ps11579/products_tech_note09186a0080b7f10e.shtml
M1 config guide
Note -- 7.0.116.0 is required to support OEAP..
If you find this helpful please support the rating system!
09-12-2011 08:44 AM
M1 config guide
09-12-2011 09:03 AM
You may also find this thread helpful. I worked with another user to get the "wired" side up on the 600.... There is also a bug you should be aware of ...
https://supportforums.cisco.com/message/3432469#3432469
